Battery charging
- Gas head
- First Name: Andy
Battery charging
Does anyone know if I can charge a lithium ion battery while it is still in place on the bike if I connect it to an oxford oxidiser x3 battery charger using the adapter connected directly to the battery
utg
Re: Battery charging
I don't beleive you should use a variable charge/load sensitive type charger on a Li-On type battery. You should use an old style constant input trickle charger.
Other than that, treat like a normal battery.
