They're easy once you get your head around it, one pipe needs to be connected to your bikes vacuum on the carbs/FI then the other needs to goto the chain. Take your time getting everything perfect.
You may need to cut the vacuum pipe (you get a t piece supplied) but make sure you got the correct pipe first
or you can connect it straight to the 'engine carb balancing points'
