I had a blow-out on the way to work the other day and had to think quick as to not be late.
As a result my rear tyre is now full of Holts Puncture foam. Was this wise or a bit stupid?
Thoughts please.........
Puncture Repair Foam in a Bike - Wise?
Not so Ginger Ninja
Touring on a Ninja is possible - If your Fathers a Chiropractor
I personally would not use anything that goes inside the tyre like that - there are many issues/faults with them all ....... though no doubt there will be as many replies saying they've never had a problem with them ....
However, in your situation, at that time, if it was the only option for you, then what the hey - you did what was right at the time. I have one of those BMW style "plug" repair kits.
Also depends on how much tyre life there is left - if it's nearly worn out there ain't much issue is there
- Mike Daytona600
I've got slime type stuff (can't remember actual name but it's not slime) in my rear tyre and is fine. I had some in the front but use to get handlebar shakes at high speed so took it out.
It doesn't make that much mess when you change the tyre at most of it is in the tyre not on the rim. You just have to give the rim a wipe off.
Parker's
Valeting
Service
Tel: 07751883056
Valeting
Service
Tel: 07751883056
- Mike Daytona600
Not so Ginger Ninja
The tyres gonna be binned now! - It was either get to work and keep my job or lose a tyre......Mike Daytona600 wrote:Oh and as for the holts type stuff read the can to make sure it doesn't knacker the tyre.
I'd only done 1000miles on it!! - Ce'st La Vie!
