Do you know anyone who works with metal?
I need a custom rear sub-frame
Jon
hi matey, ali,mig,stick,stainless. should use the codes realy.
Just finishing a swing arm on a gixer 600, extended 100mm. time and drawings would be good, as i can only do after work bits,as and when. (pj) private jobs.
[img]http://www.southwestbikers.com/images/sigs/jonoono69.jpg[/img]
:D jono
It may be easier and cheaper to use the subframe specific for the seat unit and adapt the fixings to suit the frame of the NSR. Then weld new mounting lugs to the NSR frame to accomodate the RS subframe.
no idea, how big are the battery, cdi and err? is it a race bike or a road bike? if its a race bike and you are junking the lights etc you should be able to run a much smaller battery so space may not be so much of an issue
chris_1127 wrote: is it a race bike or a road bike?
It will be a road bike eventually. But its main use will be to advertise my new company
chris_1127 wrote: If its a race bike and you are junking the lights etc you should be able to run a much smaller battery so space may not be so much of an issue
Im sure if im putting racing panels on it or not yet.
