Bought me a project
V6 Mondy
Bought me a project
Post by V6 Mondy »
Just purchased a 1986 Kawasaki GPZ550 :mrgreen:
Ok it needs a bit of work, but it runs and sounds pretty good, but
in need of a rear caliper though and a few other bits and bobs before it's
ready to visit the MOT station.
One question though, should it be run on unleaded ??
tkdsouthwest.co.uk
Re: Bought me a project
Yep, it'll run on unleaded quite happliy :D
I had the first ('83) H1 unitrack model 8) Cracking bikes for their time, though mine had a bit of a tragic history ....... looked cool though, sprayed white and floursecent green :shock: (looked better than it sounds :lol: ) had an Alpha 4-1 that apparently wasn't very quiet (there's a surprise for me :lol: :roll: )
Post some piccies - I'll see if I can find some of mine & scan 'em in to give you a few ideas 8)
V6 Mondy
Post by V6 Mondy »
er i kinda started stripping it down :?
tkdsouthwest.co.uk
Mike Daytona600
Post by Mike Daytona600 »
Beastly 8)
Parker's
Valeting
Service
Tel: 07751883056
steve-d
Post by steve-d »
Any plans of what your doing with it?
What you gonna use it for when its done?
Keep up updated.
V6 Mondy
Post by V6 Mondy »
I'd like to get it legal and then not restore, but get it looking how it should be (ie not spending a fortune) if i can
get the parts i need.
Might use it for work on those rainy days.
Are there any other similar models i can use parts from ??
tkdsouthwest.co.uk
For body panels, the 750/1100 fairings might also fit ...... the side panels might be similar to the same years z550f (can't remember now :oops: ) Mechanically, that engine is as old as the hills - many z550 bits over the years might be similar, certainly case's etc., :wink:
V6 Mondy
Post by V6 Mondy »
OK cheers, i'll bear all that in mind :wink:
First job is to get this poxy caliper working, i've soaked it in oil but the piston looks like it's
not budging :cry:
tkdsouthwest.co.uk
Mike Daytona600
V6 Mondy wrote:OK cheers, i'll bear all that in mind :wink:
not budging :cry:
Use a grease gun. Remove the caliper from the bike, put the gun on the bleed nipple and block the line hole. Rap a cloth around the caliper so the piston doesn't fire around the room (I also have the piston facing the bench,and pump away. POP :D You could also try warming the caliper with a heat gun, ally expands quicker than steel and all that.
Parker's
Valeting
Service
Tel: 07751883056
mykee
Post by mykee »
MMmmmm not bad for a project bike.
Far as I can see you only need handlebars, saddle and peddles and you should have a pretty fine ride :D
Oh, your projects not the blue push bike but the big, black beast :roll:
Best of luck with it, the gpz is a cracking bike of its time and one I missed out on in my youth.
Mykee
steve-d
Post by steve-d »
Lmfao iwas thinking what sort of bike has pedals.
Banditmax
Post by Banditmax »
Steve you had a bike which you could fitted pedals too.
steve-d
Post by steve-d »
And iv still got it, just wont start.
I was thinking of converting it to a pedal one and giving it to my dad but it would cost to much due to nos parts being so expensive.
Trying to find him a 250 superdream :)
V6 Mondy
Post by V6 Mondy »
Haha so funny !! Ner that's the ongoing kids projects, they take more bikes apart than i ever will .
Sourced another calliper, but i'll try the grease gun method first - thanks :mrgreen:
tkdsouthwest.co.uk
