Stranded HELP!
Redlight
First Name: Tony
Stranded HELP!
Post by Redlight »
Anyone know how to disarm a Datatool system 3 at the roadside???
I got a lift home with my son, but the bike is stuck in Torquay. It is not the transmitter as I have a replacement, but the F**king thing will not disarm....
Any ideas??
[img]http://www.rsvzone.com/forums/image.php?type=sigpic&userid=2104&dateline=1240582376[/img]
Re: Stranded HELP!
its the fuse, either the 10A one on the alarm or the one on the bike
Re: Stranded HELP!
a hammer :?: :wink:
not much help i know :lol: :lol: :lol:
surely its more than a simple case of a fuse and what happens when the fuse changes,does the keyfob then disarm it as normal :?:
Re: Stranded HELP!
it happened to mine, datatool vito evo, kept on going off, think it was the ignition fuse on the bike, replaced it and all worked fine after that.
Rsv4Col
First Name: Colin
Re: Stranded HELP!
Post by Rsv4Col »
Had the same problem with mine :roll:
Have you parked it near a mobile phone mast 8) try pushing it down the road leave it for a while then try starting it :?
I even called out rac they stripped all the panels but couldn't do anything as it is wired into the loom :x
I had mine removed and had a trakker fitted instead :D
Now riding a Tuono V4 1100 😀
Redlight
First Name: Tony
Re: Stranded HELP!
Post by Redlight »
Thanks for all your help. The fuses are all ok. I have just been back to the bike and after setting the alarm off a couple of times it re-set and I was able to start it as normal. This is the second time the immobiliser has left me stranded, if I can find out how to remove it....it is comming off.
Thanks once again.
Re: Stranded HELP!
Damn, only just seen this ....... I would have been happy to run down with my trailer and bring it back if needed :wink:
Offer stands to anyone - if you're completely stuck, and I am free, happy to help :D
Rsv4Col
First Name: Colin
Re: Stranded HELP!
Post by Rsv4Col »
It's not something you can remove yourself really unless you fitted it bridge charged me an hours labour to remove it but agreed to fit a trakker free of charge :shock: just had to pay for the trakker :cry:
Re: Stranded HELP!
Colin wrote:It's not something you can remove yourself really unless you fitted it bridge charged me an hours labour to remove it but agreed to fit a trakker free of charge :shock: just had to pay for the trakker :cry:
doesnt the tracker come with free fitting :roll:
i had a old skool datatool alram on my r6, insurance comp inisisted on a level 3. GT'S charged me for removing the old loom yet gopt caught out when the new one wouldnt start and it turned out to be the fact they'd wired the new alarm into the old loom they'd charged me to remove :twisted: :twisted:
Redlight
First Name: Tony
Re: Stranded HELP!
Post by Redlight »
TLS-Moose wrote:Damn, only just seen this ....... I would have been happy to run down with my trailer and bring it back if needed :wink:
Many thanks for the offer. I have it at home now and will check with the insurance company tomorrow. It has to go!!!
A beautiful sunny day.......and all I got from it was a sunburnt slaphead.
Blimey
Re: Stranded HELP!
Post by Blimey »
Same old story folks, Alarms are a f*cking pain in the arse. Who needs them? if they want your bike they will take it.
Bleedin alarms ain't worth the hassle and plus they add extra weight too :roll: :lol: :lol:
As if i would notice :lol:
Redlight
First Name: Tony
Re: Stranded HELP!
Post by Redlight »
The bike is either locked in the garage or I am sitting on it. I will have a word with Speed tomorrow and see what the score is.
Thanks once again Colin....
Redlight
First Name: Tony
Re: Stranded HELP!
Post by Redlight »
Had it removed today.......£60 and no change to my insurance premium.
Having read so many forums to find an answer to the problem, I dont belive it is anything to do with telehone masts, but more to do with a faulty motion detector. On two occasions I got it to re-set by rocking the bike back and forward to set off the alarm and was then able to disarm it in the normal manner. Unfortunatly I have little patience with anything unreliable and could not be bothered replacing the motion sensor. The Datatool system 3 is now in a bin and I will be selling the remotes on ebay.......well its a tank of gas at least.
Thanks once again to all that responded.
adam
Re: Stranded HELP!
Post by adam »
i hate them , nothing but trouble, i cut mine out to
tafflade
Re: Stranded HELP!
Post by tafflade »
On a trip to the alps last year the only snaggs we had with the (5) bikes was 2 datatool alarms, one triumph badged one went loopy and killed the engine on a motorway :shock:
my datatool 3 wouldn't dissarm at the petrol stations and peage's on the way down, it gradually got worse through the day. the first time it wouldn't dissarm for a minute or so, next time was for a couple of minutes, next time was longer then longer untill I wouldn't let it arm, it was a right PITA.
the next morning it was fine and has never given me the same problem since :?
