This is it at the mo...
Apart from a good clean
Any thoughts or advice?
Like the sound of the carb up-grade, when money isn't so tight I might look into that. Its already got a stainless straight through system on it, had to put the original silencer back on it though, the one supplied attracted far too much unwanted attentionjam wrote: Failing that you can give your 400 motor a bit more life by fitting 34mm carbs from a GPZ900 with individual filters and a decent 4 into 1 system from a GSXR400 and you should see around the 55bhp mark from it.
Or you could sell it and pick up something else more suited to modifying.
Looked into that a while ago but frame would need serious chopping about as its quite narrow.Cheese Monkey wrote:Bigger engine. Is a beauty frame, keep it!
