Last time i considered it my forks decided nope and spat the oil out so out they came and in to peak perf' for an overhaul.
This time took it for a ride yesterday, on my way back from a mates place in callington i hit false neutral (i missed a gear) then shortly after i noticed a missfire, limped it home pulled the tank off etc got the plugs out all ok, check the leads and trimmed the coil ends that were corroded.
Whilst there a stuck one of me digits in the spark plug holes and I thought number 3 seemed a bit low on compression anyway plugs back in fired it up with the tank raised up and still a miss there, pulled the leads one by one and number 3 is the problem hhhmmm, so swapped the plugs tonight but no difference. Then lifted the rocker cover to check my valve clearence and yes its way too low but not a case of no gap at all so its not a valve being held open.
Gotta wait now till i get the adaptor to do a compression test but so far its not looking good.
Anyone ever had or heard a prob due to missing a gear?
Mike
