looks good too! bit too far from exeter thoAIS wrote:get yourself up to Stonehenge way
twisty roads?
Re: twisty roads?
Keep the shiny side up, and the rubber down!
Re: twisty roads?
samZxR wrote:Looks like a fun bimble to me.Mervin wrote:Right if you want an intense course you can put these suggestions all together. Leave exeter head for Cruditon then winkleigh then torrington too bideford then down the 39 to bude/ camelford/wadebridge head back too bodmin take the 38 up the glynn valley to plymouth, you can stop for a bite at Capn jaspers then if you want, head out of p[lymouth Via kingsbridge, too totnes, newton scabbot, and then if you are pissed off with going around corners take the A380 to exter, if not Teignmouth , Starcross. powderham, exeter
If you need another route for after breakfast ask and i will suggest one![]()
ahaha!! seriously what a route!!!![]()
ill be in bed for the following 3 days after that ride
very nice tho! im up for a ride like that in a nice day with other riders, well not exactly the same route, we'll have to do some short-cuts or something cos this is just insane!
are you up for it??! thanks for the input merv!
Re: twisty roads?
im in, whenever it is!billinom8s wrote:samZxR wrote:Looks like a fun bimble to me.Mervin wrote:Right if you want an intense course you can put these suggestions all together. Leave exeter head for Cruditon then winkleigh then torrington too bideford then down the 39 to bude/ camelford/wadebridge head back too bodmin take the 38 up the glynn valley to plymouth, you can stop for a bite at Capn jaspers then if you want, head out of p[lymouth Via kingsbridge, too totnes, newton scabbot, and then if you are pissed off with going around corners take the A380 to exter, if not Teignmouth , Starcross. powderham, exeter
Mini_Beth
Re: twisty roads?
id be up for it cos then i could just meet you all in camelford then its less of a mission lol!!
will quite happily join you on this one if you decide to do it! as i need the practice too! you could also then go on from wadebridge to bodmin back to camelford up the a395 to launceston then the old road back to exetersamZxR wrote:a nice road indeed! thanks beth!Mini_Beth wrote:The road from Bude to Camelford to Wadebridge is a nice road too but that all depends on if you wanna venture down into Cornwall!jam wrote:Try the Bude to Holsworthy road, or the Taunton to Bridgewater via Williton is another good one. The coast road to Weymouth is a good one when you have got your confidence sorted.
AIS
Re: twisty roads?
collumpton up to minehead is worth a look too, thought the park, great roads and stunning views(if you ease off a bit)
Re: twisty roads?
Right the Puch maxi will be ready whenever you are
Re: twisty roads?
ahaha!Mervin wrote:Right the Puch maxi will be ready whenever you are![]()
