My bike has an ever so faint rattle coming from either the down pipes or around that area.. I'm gonna check the timing chain and tensioner just to be on the safe side.. seeing as Donny is next month and by the looks of things could be riding ther (by myself if jack doesn't sort his f!ckin bike out!
). So best to check it just incase before I go and rag the arse off it.
Never done it before.. don't really know what I'm looking for. Anything to make sure I do/do not do etc. Just want to make sure I don't take the cover off and oil will pour out all over the drive or anythin like that!
How tight should the chain be?
Will I be able to tell if the tensioner blade is worn?
Will the chain be split link or continuos?
If it's not the timing chain.. is there any baffling in the down pipes at all which could have come loose and be ratting or is there only baffling towards the end can?
Many Thanks, Tom.
