So there I am, cruising home early monday morning, when I loose drive at the back wheel????
Clutch in, negotiate several lorries to get to hard shoulder and back end locks up as i stop, wtf????
Turns out the nut holding my front sprocket on has decided to go walkabout, with the sprocket shuffling off the splind shortly after
Luckily no major damage, and the sproket was trapped in the front chain cover, but the nut was long gone....
was given the option of being taken to a bike shop at South Petherton who MIGHT have a nut to fit? I only have roadside so i would have still been stuck there if the bike shop couldn't help, so I took the expensive option and upgraded to relay cover, £109 later I'm sat in a truck on my way back to Redruth
So, one new Lock nut later, everything is back to normal but my wallet is one hell of alot lighter
The worst part about it, for the last 3 yrs everytime I'v changed my chain and sprockets, the front sprocket nut has had to be undone with a air powered impact driver, even a very long bar has failed to shift it, and we've always done it up with the same impact driver and tab washer to lock it, so how the f**k did the nut just decide to undo itself
By the way, how is your bike Sheila? Did the problem persist on the way home or did it fix itself?
