FZR600 spluttering its arse off
any thoughts folks , 89 Fizzer 15000 miles runs fine til about 6000 rpm then really holding back t , you know like the old LC's did with spannies on just before the band if not 100% set up right . Its same with race can and std can ! All input welcome its spoiling acracking little classic that likes to be spanked.
- goatpants
- First Name: Chris
Re: FZR600 spluttering its arse off
Jetting issue as in blockage? I used to have a 89 genny 600
Running on MT
Check the pick-up coil. Haynes manuals have the specs, check with a multi-meter. Then take the carbs off and totally clean them, check all the o-rings and the diaphragms for cracks/pin holes.
If those don't work start looking at coils and leads.
Should be the first two item as these bike run a wasted spark system and faults on all four cylinders is unlikely to be caused by two bad coils or four bad plugs or leads/caps. Not unheard of, unlikely.
Where you at?
Where you at?
Sunny Plymouth , suspect carbs bikes only done little miles and oureco friendly fuel likes to turn into treacle after a few months ......cheers for the pointers bikes as sweet as can be under 6 thou .
Don't rule out that pick-up yet!
I'd go through the lot to be honest
New plugs, give the carbs a soak in fresh petrol then a good clean out. Empty the tank and put some good fresh fuel in it. Check the wiring to the coils and the condition of the plug leads and caps. Turn the bike over with the plugs out and make sure you have a nice fat spark to all four, then chuck it back togather and see how it goes
Cheers looks like i will be tinkering rather than riding this weekend , will get some new carb bowl O rings ordered up and suck it n see !
You can use normal o-rings from your hardware store. They are the exact same, just double check they are black and importantly, made of nitrile. 99% of black o-rings will be nitrile. This is what I have used on my FZR1k, they work perfectly. Grease them or coat with oil before you press them in as they'll most likely split.
On your float bowls - if the gasket looks a little squished you can use an oilstone to take a tiny bit off the face of the bowl, clean all the grooves and hey presto, a perfect seal.
If you have a mikuni cv carb you may have a seal beneath the main jet housing, if so you can do the same trick here too. Just don't remove too much material and ruin the part.
Check the slides move freely and equal.
The smallest split in a diaphragm can also cause significant problems.
Spray carb cleaner bloody everwhere, through every tube and jet. DO NOT damage the bores of any jet or passageway.
Have fun.
Have fun.
Thanks for the input ...i hate carbs ....4 of em what joy ! Got to keep the old timer spinning tho .
[BBvideo 425,350]http://youtu.be/MNA6aStkAeU[/BBvideo]
Hope the linkworks , here she is at 23 years old .
Good info off Dan..............done loads of them back in the 70s and early 80s...........done my vfr carbs twice since ive had it [13 yrs].....and you know what there like to get off, but what a difference....
hope you get on alright with them and it cures your probs..........I think that Dan,s the man for any fzr info
started tonight , panels off , dummy tank off , petrol tank off , so far so good .....took the lid off the air box and out if flowed tons of what looked like eaten nuts and seeds in the centre of the air filter ! Full to the top too ! Some little varmit has been living inthere i knew the bike had not done much service at 23 years young and 15000 miles but this was unbelievable ! Took some pics if i was not stupid i would put a couple up for ya , talk about a blocked air filter !
Pretty chilled out taking it apart , spannering with some good tunes is very theraputic !
Any luck Picks?
Not yet mate , picking up new carb gaskets tomorrow so will put it back together sat pm , carbs like new inside , diaphrams look fine too so hope its down to the air flow . Or lack of ! Gave the carbs a good blast of cleaner , will do em again before refitting .
