Didi not expect to find
Picks
Post by Picks »
whilst stripping the bike down to get the carbs out an airbox choca block with what looked like bird seed !
Husts , empty sunflower seeds looks like some little fur covered fellers been living it up right to the top of the centre of the round air filter element , about the same size as a large jar of coffee ! This lot must have ben putting a strangle hold on the air getting to the carbs !
Anyone else suffered at the hands of a cheese yamaha carb bowl screw , Jesus what a nightmare , ended up cutting a slot and bringing out Mr Impact Drive on two of em ....did the trick .
Re: Didi not expect to find
My Landrover had a dead bee's nest and half a forest in it when I got it =))
silvertonkate
First Name: Kate
Post by silvertonkate »
I've got a moth living under my seat...
Free with every motorbike: you.
PLEASE VISIT MY FACEBOOK PAGE
https://www.facebook.com/pages/Nutshell ... 1961029125" onclick="window.open(this.href);return false;
Dead spider fell out of my Carbs when i cleaned them the other week,the pick up is much cleaner now :)) :)) :))
Smiler
Rideout Ringleader
Post by Smiler »
My insurance doesnt cover me for carrying passengers.... :mrgreen:
dan90210
First Name: Dan
Post by dan90210 »
Replace the float bowl screws with stainless allen screws. You'll regret it next time otherwise. Double check this but I think they should be M5 by 18mm or something like that.
The screws are made soft so the user does not strip the thread on the carb body, very expensive to put right. Also be careful not to snap a corner with the impact driver. The top screws can be a sh!t too!
If you use the stainless allens just be careful not to strip any threads or replace with Yam screws again.
graham22
Post by graham22 »
I have a slug or snail living under the bonnet of my car. She (must be by the trail :twisted: ) goes for a wander around the bodywork each night. Hopefully it will fall asleep on the turbo.
Mines got a d!ck riding it
silvertonkate wrote:I've got a moth living under my seat...
Fnur, Fnur, so many double-entendres for that I don't know where to start .......
graham22 wrote:I have a slug or snail living under the bonnet of my car. She (must be by the trail ) goes for a wander
Graham, honestly ....... :ymblushing: :roll:
albieplums
Post by albieplums »
Did it smell like popcorn when you were bimbling along!? Sweet as!
silvertonkate
First Name: Kate
Is your real name Finbarr Saunders?! :)) Thought I might cop it for this...
Picks
Post by Picks »
The carbs look very clean inside , guess my problems could have been down to the blocked up air filter , took the jets out blew em thru , lots of carb cleaner and new gaskets coming tomorrow so will put it back together and suck it n see !
Are they CV or slide carbs? if they are CV's, check the diaphragms for splits. Also, check all vacuum pipes/plugs from and around the carbs - any leaks from them will produce the symptoms you describe :wink:
