Muvvvwww MOT
goatpants
First Name: Chris
Muvvvwww MOT
Post by goatpants »
Muvvvwwwwwwwww is in for an MOT tomorrow :-o :-ss :-ss :-ss
Smiler
Rideout Ringleader
Re: Muvvvwww MOT
Post by Smiler »
She'll be fiiiiiiiine! :ymhug:
So is Bluey btw, a little prayer if you don't mind? :-*
Re: Muvvvwww MOT
I often wonder why people worry about bike MOT's so much ..... surely with a bike, most of the things that are likely to cause a fail are immediately obvious when cleaning/maintaining - bearings, brakes, tyres, lights & horn ...... the one that I usually forget and resolve with a £1 purchase on the day is the rear reflector :oops:
goatpants
First Name: Chris
Re: Muvvvwww MOT
Post by goatpants »
Rear brake needs bleeding, got my "aherm" integrated indicator back light thingy on. Bit of a grey area that one.
Smiler
Rideout Ringleader
Re: Muvvvwww MOT
Post by Smiler »
You say that Moosey but Lottie lost her horn in France a couple of years back...I kinda forgot :oops: =))
Re: Muvvvwww MOT
goatpants wrote:...... got my "aherm" integrated indicator back light thingy on. Bit of a grey area that one.
No grey area mate, they're illegal - construction & use regs apparently say indicators at the rear of the bike must be 280mm apart, spaced equally from the centre-line of the machine ...... just hope for an "understanding" tester ......
cobrabuilder
First Name: Darren
Re: Muvvvwww MOT
Post by cobrabuilder »
Yeah heard on another forum New regulation has been sent out saying integrated rear lights are to be failed and led rear clusters must not have more than 4 lights out either :(
scorcher
Re: Muvvvwww MOT
Post by scorcher »
KTM's in for its 2nd MOT this morning aswell and a new rear hoop. Still haven't got around to fixing the number plate bulb from last year he mentioned (not that its a MOT requirement) Should pass no problems. Not sweating but then again its not a Triumph is it!!! ;) :)):
Re: Muvvvwww MOT
My Mot is coming up this month also.
Re: Muvvvwww MOT
Intergrated rear lights are a failure as creates a major interferance with the rear light,
As for 4 leds a failure, in cars I know its 50% of the light so dont know how true this is,
scorcher
Re: Muvvvwww MOT
Post by scorcher »
And its a pass (with no advisories)! :D Rear brake pads are still the originals, and as he started to loosen the rear wheel I had terrible thoughts that the friction material might of become detached from the backing plates like they had when I removed the front wheel a few months ago. Luckily all still in one piece. Have to get some new ones soon though :)):
goatpants
First Name: Chris
Re: Muvvvwww MOT
Post by goatpants »
scorcher wrote:KTM's in for its 2nd MOT this morning aswell and a new rear hoop. Still haven't got around to fixing the number plate bulb from last year he mentioned (not that its a MOT requirement) Should pass no problems. Not sweating but then again its not a Triumph is it!!! ;) :)):
You wish!!! :p :p :p
goatpants
First Name: Chris
Re: Muvvvwww MOT
Post by goatpants »
I got a fail on the light but now ready for re test
