I'd bin it too, having been 'immobilised' in Lynmouth one afternoon after stuffing waterproofs under the seat of a VFR, disturbing an indicator connection which mean't the alarm wouldn't dis-arm because it couldn't flash the indicator (safeguard I guess as early alarms could be by-passed by removing an indicator bulb).
Whilst it might have been an insurance benefit/requirement whent new, it's unlikely to have an effect 14 years down the line.
I removed mine myself, just took some time, checking where the wires went & ensuring any of the bike's own wires were reconnected if they went 'through' the alarm.
Data tool veto evo
Re: Data tool veto evo
Ahh man, I'm getting fairly sick of my veto evo too.
I've been trying to do some simple jobs replacing brake pads etc but having to leave the ignition on so that the alarm doesn't go off...forgetting I left the hot grips on....off comes the side fairings and seat to get to the dead battery.
I reckon it will be less faff to remove it in the long run.
Did you sort your issues out with it gas head? well done on the test!
black & silver cbr600 F3 (matches my noggin)
- Gas head
- First Name: Andy
Have left it alone. Seems to be working okay so will continue to leave it alone. Over the moon to be on the road with the fzs600. Thanks
utg
- jer r1
- First Name: jerry
Put it in service mode if you want to work on / clean bike.hillbilly wrote:Ahh man, I'm getting fairly sick of my veto evo too.
KEEP CALM
AND
POWER ON
AND
POWER ON
Thanks for the tip about service mode, didn't realise it had such a thing.
I reckon I will get rid of it though
I've had one on my last two bikes and (fingers crossed) had no probs.
As with many other things, excellent when they're working and a ******* nightmare when they play up.
Saves a few quid on the insurance as well.
do you still have the diagram I’m having a nightmare with mine and wish to remove itbillinom8s wrote: ↑Sep 30th, '16, 17:44 i had a veto evo on my r1, until it got spiked by a mechanic who was working on it and blew it up. so have the wiring diagram here if you need it.
If you're removing it you don't need the diagram. Just following the wires. If they piggy-back a wire, just de-solder & make good. The four wires that go to the two cut wires of the main loom will be in the OE colours still, so de-solder the joints and re-solder the appropriate original wire ends back together.Joe wrote: ↑Jun 23rd, '19, 19:28do you still have the diagram I’m having a nightmare with mine and wish to remove itbillinom8s wrote: ↑Sep 30th, '16, 17:44 i had a veto evo on my r1, until it got spiked by a mechanic who was working on it and blew it up. so have the wiring diagram here if you need it.
Place old alarm in trash can
Job done
I have the bypass pins that need to be linked out. Drop me a line via text and i'll let you have it.
