N/S Fairing smashed into 10 or so pieces. Some other cosmeticals. Gear lever demolished. Water pump housing holed. One bar end damaged. Started first time but as no water, turned it off immediately.
2 metre skid mark on road but no other indications as to cause.
Arrived in double-quick time with SOS Bike Recovery from WsM. Helpful, knowledgeable and courteous.
I'm in neutral at the mo but when I can get it on the centre stand and regain some bodily strength, we'll have a look. Can't get full lock one side, brake pedal jammed.
In vino veritas
Good luck on that one, if the motor is running thats a start. After that its check the frame is straight. If that's good its strip and rebuild and back onto the road !
MellowYellow wrote: ↑Aug 20th, '18, 18:55
Had to remove horn in order to stuff 8 miles of electrics into front fairing.
90% done, re-fit horn tomorrow and fit RH side panel.
Of all things to get in the way the horn was a problem
Motorbike horns are small little round things.... of all the things to get in the way
