help me, my bike wont start
RogerSmith
Post by RogerSmith »
Have you blown any fuses on the bike?
Before attempting to start the bike, how long (days/weeks) had the bike been sitting about?
If your bike is a Carb'ed version and it's been sitting around for a while, it could be that the fuel in the float chambers has gone off (de-stablised) which could be the cause...
In which case flush fresh fuel though and get some Silkolene Carb cleaner.
Also when trying to start the bike do the lights on the dash virtually die (i.e. go off/very dim) in which case the battery might be tired and need topping up/replacing as required.
georgie_d
Post by georgie_d »
BOSS wrote:I must agree with Clunk, CHECK THE BATTERY before you do anything else.
You missed a lovely ride Georgie :lol: :lol: :lol: It was brill. :lol: :lol:
yeah cheers boss rub my nose in it i was gutted mate i had to go bloody toysr us instead :cry:
07814071582 [img]http://snap27.photobox.co.uk/944877546d0c3b02d6911b465275d7134300550b43a3c7a785626a35.jpg[/img]
georgie_d
Post by georgie_d »
i charged up battery and nothing so i tried bump starting it in all the gears and nothing apart from the wheels locking up. checked the fuses and they are fine, cant believe it, i feel quite upset about it really, cus i love my bike :cry: :cry: so i am going try and get hold of a battery checker and see if its nackered maybe, i am really worried it might be something like a piston or the head??? would it do that sort of thing if it was?
AndyCBR
Post by AndyCBR »
Started my bike for ride out this morning, fired up first time, selected 1st - bike stalled & engine cut out (left side stand down :oops: ). tried to start bike again & all I could get was a clicking noise - engine would not turn over! lights everthing worked etc. in the end bumped started bike down hill engine fired up everthing normal. Cut engine & tried to restart nothing accept clicking thought starter motor was shot!! bump started again fired up - went for ride out (fantastic :D ); have had no probs since. Starter motor, solinoid may be sticking !! Long winded I know but sounded similar to your problem (CBR 600F 2000).
georgie_d
Post by georgie_d »
ok today i have taken the battery off and took it to halfords for a check and it was ok so i think next i may try the plugs real involved to get to them though :roll:
CBR_LOVER
Post by CBR_LOVER »
georgie_d wrote:think next i may try the plugs real involved to get to them though :roll:
Tell me about it!were a nightmare to get at on my cbr - you need fingers like
pool cues :roll:
sprocket
Location: If ya sees me ya sees me | Cracked Silver K2SV650S
Post by sprocket »
You said it went bang, where from? If you can locate the bang them maybe you can find the problem.
[b][size=200][color=RED]DID A WET LAP AT NURBURG[/color][/size][/b]
Is it a bird? Is it a plane? No its a sprocket!!
Bunny
First Name: Bunny
Post by Bunny »
Does the engine turn over when you press the start button ?
no use checking plugs if the motor is not turning over
Cheggers
Post by Cheggers »
I've got a battery that you can have for cheap. only bought it a few months ago.
Rides - 2008 R1
1980 CB250RS
Drives - Honda Motegi Prelude 2.2 VTEC
Leroy
Post by Leroy »
I have a brand new battery in my bike and still every morning i have 2 bump start it. It can't handle the cold. Luckily its easy 2 bump and gets going straight away! :roll:
Tom L
Post by Tom L »
has this problem twice on my bandit. First time was beacuse i used to go out everyday and just start it up in the drive way through winter to keep it in use. but beacuse i didn't drive it anywhere the plugs gunked up. Second time, now this is pretty rare but if you cant fix it look into it. My bike has a jobbie that wont let the starter engine work or let the engine tick over if the side stand it down. Took me fecking ages to work that out. Beacuse the mechansim on the stand jammed about 1 - 2 cm from being fully folded up. So it looked up but it drove me mad, have a look.
Post by chris_1127 »
georgie_d wrote:i charged up battery and nothing so i tried bump starting it in all the gears and nothing apart from the wheels locking up.
does the engine turn over at all when you try to bump it, or does the wheel lock up the minute you release the clutch? if it locks immediately and wont even turn when you bump it in 2nd, 3rd or 4th then it sounds like the engine is siezed for some reason. Try lifting the back wheel off the ground, putting it in high gear and try turning the wheel to see if it turns engine over (ignition off just in case ;))
The clicking you hear when you thumb the starter is the solenoid so power is getting through that - if the solenoid was jammed it wouldnt click.
where abouts in Newton Abbot are you? could have a quick look after work some time if you wanted?
georgie_d
Post by georgie_d »
well it doesnt sound good cus i tried putting the back wheel up and turning it in a high gear and it just wont bugde i think the bang i had was backfire :?: gutted :cry:
age
Post by age »
take the plugs out mate then try to start it. It might turn with no compression
PS3 name lesnage
georgie_d
Post by georgie_d »
AGE996 wrote:take the plugs out mate then try to start it. It might turn with no compression
ok i shall try that so peed off at the mo about it i will try anything
