Yea I meant CDI but CDI/ECU same difference lol I have been fiddling around moving the ECU on the ZX12R so I was probably thinking of that sorry
Dead ZXR HELP
Re: Dead ZXR HELP
Everything is seeming to work except occasionally it refuses to start
put the key in and it's all fine hit the start button and everything goes then wait a couple seconds it all comes back and usually starts that time!
[img]http://img.photobucket.com/albums/v233/dodgy_rider/dodgybanner.jpg[/img]
Re: Dead ZXR HELP
Mine used to be annoying like that, the problem was the neutral starter switch, it was cutting everything out when I pushed the starter button.
Re: Dead ZXR HELP
The what now
how do you fix that?
It's really annoying
Re: Dead ZXR HELP
Theres a switch attached to underside of the clutch lever, the problem I had was the neutral switch thats behind the sprocket case, that connects to engine, filled with crap, making bad connection and kept falling off, sometimes it would say its in neutral, push the starter and all lights and power go out, take off button and it comes back again.. starts ok if you pull the clutch in.
Well strange, since then I have changed alot of plugs and wiring on the bike to new stuff and have had no electrical problems since.
Re: Dead ZXR HELP
i thourght that imports u had to hold clutch in to start them? so maybe im wrong?my SV400S i have to hold clutch in to start her, thourght this was normal grey bike behaviour so jap law or somthing. So how do i stop it?ZXR400Lee";p="35333 wrote:Theres a switch attached to underside of the clutch lever, the problem I had was the neutral switch thats behind the sprocket case, that connects to engine, filled with crap, making bad connection and kept falling off, sometimes it would say its in neutral, push the starter and all lights and power go out, take off button and it comes back again.. starts ok if you pull the clutch in.
Re: Dead ZXR HELP
My bike isnt an import.. you could stop it by removing the little switch from underneath the clutch lever, you just un-plug it.. but then you run the risk of accidentally pressing the starter button with the bike in gear and dropping it on the floor..
