From what you've described you've tested the plugs &/or coils. Although the fact that the spark is faint does point towards the coil/plugs being the problem, or maybe part of it. Is the spark from 2 & 3 similar to 1 & 4? If so, they may be ok, if not there's the problem (or part of it!!!)Little Loris wrote:I've done a dry test (I think?) where I'm putting the plugs in the HT leads and turning the engine over. The old man said he could see sparks but faint ones?
Try changing the coils/plugs from 2 & 3 for 1 & 4 & see if the problem moves, ie: 2 & 3 missing. If it does, then it's the coils/plugs.
If you want to do a compression test you'll need a compression test gauge like this one;-
http://www.mandp.co.uk/productInfo.aspx?catRef=529641
