Newbies.. Ask us Anything??
Re: Newbies.. Ask us Anything??
Bendearb wrote: Aug 18th, '18, 13:41 Just got to having a look at the stator and checking the resistance and the connector is totally melted and perished could this be the cause of my problems?
Yes, it could be... but don't assume it is.
Do the resistance checks for the stator coils, if they look within spec then do the output voltage tests with the engine running.
If it's melted the plug then it needs replacing.
Robbo87
Post by Robbo87 »
Bendearb wrote: Aug 18th, '18, 13:41 Just got to having a look at the stator and checking the resistance and the connector is totally melted and perished could this be the cause of my problems? .........
So it's not just 17 year-old Aprilia's that do this then :mrgreen: ?
Whatever's been said about getting it all sorted soonest is absolutely the case. Leave it, and you're looking at a new wiring loom, also generator/stator, regulator/rectifier, battery, and most associated electrical parts - it'll get expensive and your bike will be off the road for a while.
You may be lucky and the melted connector is the only early casualty and that by replacing it you'll have caught it all in time - but if it's got to that stage I doubt it.
The connector gets over-hot and will eventualy melt because, over time, the crimped connections within develop more and more resistance. Also, in most cases, the wiring is too small a gauge.
I can't speak for your bike, but the above prob's are a well-known part of Futura ownership so I was aware. I caught and fixed the main issues early on.
Fut-wise (and I'd like to bet lots of other bikes fall into this) there are three main charging circuit weaknesses.
1.The dreaded brown connector (dreaded by Fut owners anyway because it ALWAYS fails eventualy), which joins the stator cables to the reg/rec and which has only crimped cable connections, not soldered. If all else is well, this is the first thing to rectify; normaly, if you've caught it in time, that then gives 2. & 3. (below) a fighting chance of survival.
2. The regulator/rectifier, which is not of the best quality.
3. Charging circuit wiring which is too light in gauge.
The recommended Fut charging issue mod's are this: (a) Where possible, replace the standard wiring with a heavier gauge. (b) Solder all crimped-only connector joints. (c) Fit best quality connectors; or no connectors at all and just solder the wires together and (d) Hope you've caught it in time :?
billinom8s wrote: Aug 18th, '18, 18:39 If it's melted the plug then it needs replacing.
Yes & No.
You can bare the wires and simply crimp to rejoin them, or solder them. A crimp joint is better than a soldered joint IF done correctly.
Correctly means correct size crimp for the wire and a proper crimp tool (ratcheting type), not the cheap ones DIY.
Both the above are generally better than a connector.
The connector failing could be the only issue here, and if so would not cause any harm to the stator or the R/R. In this situation the battery can be harmed by over discharge (which will most likely just reduce it's charge capacity), unless it was already on its last legs.
Jug_Inspector wrote: Aug 19th, '18, 11:23
Yes & No.
But then can't check the condition of the connectors properly and if gotten hot, could be prone to fracturing.
Correct crimp size I completely agree with as seen people using wrong sizes before, but as for ratchet crimps, I would still prefer my branded non-ratchet crimps compared to cheap cheap bin fodder ratchet.
Ruffian wrote: Aug 19th, '18, 12:49 But then can't check the condition of the connectors properly and if gotten hot, could be prone to fracturing.
You've confused me here.. are you saying that if a connector is used then you can periodically inspect it?
If so then yes... but if you use sealed crimp then you can be sure that it hasn't deteriorated as it's heat sealed after crimping. You could also use clear covered crimps which will discolour if excess heat is generated.
Crimp tool - as long as it's a proper tool that has been setup to provide only the correct crimping force (and no more) then you're good. The bonus of the ratcheting type is they won't allow you to stop until the correct force has been achieved, the non-ratchet type will let you under force a crimp so it's kind of guess work for how hard to squeeze.
The ratchet type click when you've done enough. :)
Chris88
First Name: Christopher
Post by Chris88 »
Hi guys th8s it's my second post here on SWB
Here is a newbie question and problaby one of a many as I have no close friends that ride bikes at all.
Is it "illegal" to put stickers on a helmet?
To explain better that simple question is because I will be driving on nights trought a30 one to launceston and as in France I would like to put reflective stikers on my helmet.
It's silver same colour as the reflective bands we see on the hi-vi so it might help
Thanks in advance all :ympeace:
Life is not about waiting for the storms to pass: it's about learning how to ride in the rain!!! :ympeace:
Chris88 wrote: Nov 18th, '18, 21:39 Is it "illegal" to put stickers on a helmet?
I have never come across any law that you should not put a sticker on your helmet.
However there is a concern about the outer shell of the helmet and depending on what the helmet is made from the glue can weaken the helmet.
Follow this link and watch this short video this should help
https://www.motorcyclenews.com/new-ride ... my-helmet/
If you need to know what your helmet is made of then take a look at this site
https://sharp.dft.gov.uk/
Chris88
Post by Chris88 »
Thanks Menzies3032
Not illegal. New lids actually come with them in the box I think.
It used to be you had to be careful putting stickers on lids due to the solvent I'm the glue reacting with the helmet materials and weakening them. Pretty sure helmet tech has improved though.
As long as it's not a cheap thermoplastic helmet, you should be ok. If in doubt ask the manufacturer/distributor/supplier....
Chris88
Post by Chris88 »
Thanks billinom85
Yeah I was talking the other day to some chap and he used to be on the scooter crew and he told me that insurance policies if I have a crash they will dump the case if any non factory sticker is on due to "making them unsafe"
I was finding hard to believe as now a days we can even fix a go pro and Bluetooth to our helmets... :-?
What make is the helmet? I have some of the genuine Shark French compliant ones here, and I might have some Arai ones here too, if I can remember where to look ....
Chris88
Post by Chris88 »
TLS-Moose wrote: Nov 19th, '18, 00:26 What make is the helmet? I have some of the genuine Shark French compliant ones here, and I might have some Arai ones here too, if I can remember where to look ....
hey TLS-Moose
my helmet its a caberg v2 407
metalic silver
Davey boy
Post by Davey boy »
Hi ,is there any way members from bridgwater and surrounding areas can be linked ,there are a couple of us who ride out from bridgy but I'm sure there are other people left twiddling there thumbs unaware and would possibly like to join in .most of the swb action appears to be quite a way from bridgwater which means it's a ride out to join the ride out.just a thought is there anything that can be done to help.thanking you in anticipation
Regards
Dave 07703289710
