Helping a friend
Posted: Apr 1st, '22, 18:31
by FazerBez1
Wild one here. A friend's industrial glue gun has broken. There is a threaded brass piece stuck in it. The bit you'd normally 'grab' snapped off. I'll try znd post pics. He's in exeter but I'm torquay. Anyone far and wide can help it would be ace. Cheers
Bez
Re: Helping a friend
Posted: Apr 1st, '22, 18:46
by Jug
Dremmel some flats across it and then use a flat blade to turn it maybe?
Actually, more like then use a cold chisel on the flats to start it turning...
Posted: Apr 1st, '22, 18:47
by Ruffian
If its threaded, just tap a torx or multispline into it and then just undo it.
Posted: Apr 1st, '22, 19:40
Easyout ?
Posted: Apr 14th, '22, 12:13
by FazerBez1
sorry for the late "thanks for the advice" friend sorted it and the boss was none the wiser. cheers guys
