Tyre pressures
brummyscouse
- First Name: martyn
Tyre pressures
Hi all just wondering what's the best tyre pressure for front and rear on my 2001 zx9r as feels a bit hard at moment when out
Re: Tyre pressures
36 F
42R
42R
Re: Tyre pressures
That's nearly as bad a question as what oil to use. The handbook says 36/42 for a reason, though wiser people will say different
Re: Tyre pressures
Stock pressures for your ZX9r would be f36 - r42 psi but there are many variables within that i.e. tyre make and model, weight, riding style etc. etc. The handbook pressures for my Triumph Sprint ST 1050 (with 120/70/17 front and 180/55/17 rear) is 36/42 psi, but I'm running my Pilot Powers at f33/r38 psi and the difference for the better is marked.
Re: Tyre pressures
Many peeps seem to benefit form a couple of lbs down front and back, I've always stuck to standard.
