how do i stop my boot's squeaking
I have new OXTAR boot's with the ankle support on the back. they squeak like mad when I walk. anyone know any trick's to stop them squeaking
Re: how do i stop my boot's squeaking
squirt a little 3 in 1 oil in round the ankle support, this should stop it mate
[b][color=#FF0000]wait till you see god [size=150]THEN[/size] brake !!![/color][/b]
soak em in waste oil, it, waterproof em as well
merv
merv
Ha. i would rather not soak a pair of £120 boot's in waste oil. which sort is 3 in 1 oil. I was thinking either WD40 or copper grease.
Billinom8s sprayed mine,oxtar boots
!!! with silicon spray. Only thing to have worked, but just for a few hours!! You just got to get use to them squeaking mate
, if you find a solution let me know
[img]http://www.dynamight.pwp.blueyonder.co.uk/sig/juliansig.jpg[/img]
Iv got the same boot, had them for 6 months, still squeak, tried everything, just gave up.
More seriously i use a leather waterproofing treatment called Nikwax if you could work that into the affected area it may help, you can get it from Trago mills ,busters , some bike shops, shoe shops etc there is also a number of spray on products they make, visit there website, http://www.nikwax.com/en-us/index.php
Merv
Merv
WD40 or standard boot polish. both have worked on my sidis
SlowR1der
seems to be common with OXTAR boots, i bought mine in December used some spray grease on em and it cured one but not the other. Seems to be the pivot on the back of the heel on mine
k7 dave wrote:After a ride i just spray wd40 over them seems to work
snap
works with my oxtar every time
i've got a pair of the same boots and squeak like crazy, i tried everything but nothing lasts. regular WD seems to do the best though
Banditmax
just ride your bike everywhere don't walk in them.
