Dry cleaning your leathers..
Posted: Feb 24th, '09, 15:30
by JimR
Just been to get a quote from Johnsons to get my leathers dry cleaned, 90 quid for jacket and trousers!!
Is this normal??? what do you guys do with yours?
Re: Dry cleaning your leathers..
Posted: Feb 24th, '09, 15:32
pm lwr gerry, she knows all about that stuff
Posted: Feb 24th, '09, 22:29
by philh
If it's just the outside that needs sprucing up, then I've always found that a good scrub with baby wipes followed by a proper leather wipe/feed works great!
If the inside is stinky then I guess you'll need something more... :P
Posted: Feb 24th, '09, 22:35
by dougal_999
All I've ever used is Nikwax Leather Cleaner and then the Restorer which waterproofs too. In all honesty I've never done the insides so I don't know! Hmmm that makes me sound scummy doesn't it... :roll: :)
Posted: Feb 24th, '09, 23:13
by Varcon
Mine go in the washing machine on a low low low heat wash. Says its ok on the labels so i guess its ok.
Although that only gets done once a year if that - usually its just cleaning the outside, in which case i just use a damp cloth, and then proper leather wipes, and then a leather feeder.
Posted: Feb 25th, '09, 17:09
by LWR GERRY
http://www.leathermagic.com/Pages/careforleather.htm
I think you should read up on leather care before you think about putting them in a washing machine!
Hope this helps.
Also, this was put up ages ago but full of useful suggestions!
http://southwestbikers.com/viewtopic.ph ... a&start=15
http://southwestbikers.com/viewtopic.php?f=36&t=80165
Posted: Feb 25th, '09, 19:11
by kestrel69
I do the outside with NikWax leather feed.
The inside gets a quick burst of sanitiser spray, same stuff you get for doing insde helmets & boots. Stick them on a hanger & leave them outside for a couple of hours to air out :D
