Help, 3 Days until I leave for dubrovnik
Posted: Jun 18th, '09, 18:43
by Beejyman
Electrics are playing up, It's not uber serious as bike has a kick start, but would be good to get iorned out. Electic start won't work, first started buzzing when pressed now just clicks. Lights are working though but Odometer isn't util the bike is kick started
I have a Data tool system 3 fitted and half the time when arming the alarm it just goes off??
Please help any ideas, I Have about 24 hours to get it fixed.
Re: Help, 3 Days until I leave for dubrovnik
Posted: Jun 18th, '09, 19:18
by r1dave
Hows your battery m8 as a start point
Posted: Jun 18th, '09, 19:26
by Beejyman
Just cleaned the terminals and leaving it on charge overnight. But as lights etc are working thought it's prob something else.
Posted: Jun 18th, '09, 19:28
by tutton
Stick multimeter on it with ignition on
then stick it over while cranking the bike, see what voltage your getting under load, could still mean the battery cant cope to start it as its a huge pull compared to lights etc.
Thought about bridging the starter to make sure its still turning?
Posted: Jun 18th, '09, 22:23
its the battery. Bulbs take a tiny amount of power to work where as a starter is a greedy bugger. I'd be a bit concerned however if it has just dropped off and died, especially just before a joni journey. If a cell is on it's way out then charging it might give you a couple of starts but it could die at any time. Best get a new one then check the charging voltage and make sure its within specified range. Have a good trip.
Posted: Jun 19th, '09, 08:49
by Beejyman
Thanks guys I'll pick up a new one today.
Posted: Jun 19th, '09, 11:49
by PeterM
Have a good trip
I arrived back from Dubrovnik after a round trip of 3700 miles last sunday and it was brilliant
If you have nowhere to stay in Dubrovnik yet suggest you stay In Cavtat (South of) and then take the boat into the old town
When you get into Croatia do not not under any circumstances deviate from the coast road its brilliant especially the Celce bit too Zadar (be careful as the signs might try and take you inland about 50 miles from Zadar)
Travel across from Italy at Trieste as the roads through Slovenia are back roads and do not incur the charge of 17 Euro's
Check out my blog at
http://stx1300.blogspot.com
I wish I could be more helpful but I am in 10 mins leaving for a weekend away but you are more than welcome to email me direct if you need more info
Regards
Peter
Posted: Jun 21st, '09, 16:06
by Beejyman
thanks for all the advice, Only an hour or so before I depart (only doing a few hours to my bro's house then ferry in the morning), will keep your email incase i need any advice.
