quickshifter
Posted: Sep 9th, '09, 20:26
seen a techtronics quickshifter 4 sale,just wondered exactly they did and how they work,and are they any good
The UK Based Forum for Bikers in the South West
https://southwestbikers.com/
You're confusing Quickshifters with Air or Nitrous shifters. A quick shifter is typically a tension/compression activated microswitch connected to the gearshift pedal and is activated y shifting the gear pedal as normal and works by cutting the ignition for a few milliseconds which unloads the gearbox and allows full throttle clutchless upchanging without the need to dip the throttle. Airshifters and Nitrous shifters work in a similar manner but use a gas powered ram connected to the gearshift pedal to shift gear whilst cutting the ignition for a short period. Air shifters typically work at around 150psi and Nitrous shifters at around 900psi, which shifts a lot faster, but can suffer problems with Nitrous gas freezing in the ram.billinom8s wrote:think they are mainly for drag racing. NotNot really much use on the road.
If it is set up correctly there is no reason why it should have a detrimental effect on the gearbox. Air/Nitrous shifters can damage the gearbox if activated whilst the engine is not running, but a normal quickshifter should not harm the gearbox if the kill time is set properly.graham22 wrote:Shorten's your lap times & your gearbox life!
