Is it bad for my bike to not use the clutch while up shifting ?
I use the clutch to get from first to second but hardly ever past that. I've read a lot of other forums and people have differing opinions, just wondering what you guys thought.
Quick question
Re: Quick question
As long as you drop the slightly throttle to unload the gearbox then its perfectly fine to do clutchless upshifts.
Re: Quick question
As long as you get the revs right seems cool, but it can lead to a missed gear or have it jump out of gear although seems to depend more on the bike
Re: Quick question
Me too, works fine on chain & shaft drive and 1 or 2 up. It's the only way to shift when riding fast and on long journeys - once you've got the knack it works a treat.
Down shifting's a bit more tricky and I've found I need to throttle right down to low revs before bliping the throttle slightly while easing the shifter.
At the risk of sounding a bit hippy... I think it's a bike harmony thing
Steve.E
Dragonforce Kin
Re: Quick question
I have found that occasionally I hit a false neutral and it makes a nasty crunching noise!
Just hoping it doesnt do any damage, and I'm not brave enough to shift down clutchless yet haha
