removal
Posted: Feb 25th, '14, 12:26
by driverbrook
Hi, need advice. I have a cruiser that at some time in the past has had these mudguard embellishers added, you know, the ones that stick on the leading edges, anyway they are now getting really tatty, the chrome which was wafer thin has started to peel off and the alloy underneath is grey and furrey, my problem is trying to get them off without damaging the paint, anyone know of a solvent that would remove them as they are really on to stay, the double sided sticky stuff they are on with is powerfull, would be grateful for any ideas, cheers, Arnie
Re: removal
Posted: Feb 25th, '14, 13:13
by zing1100
Gently does it with the aid of a hairdryer on low. It's how i get my old tank protectors off when they get tatty.
Re: removal
Posted: Feb 25th, '14, 16:40
by driverbrook
Hi Zing, thanks for that tip, will try, let you know how i get on, cheers, Arnie
Re: removal
Posted: Feb 25th, '14, 23:04
by badgerKDD
I tend to use lighter fluid, it gets off glue residue without damaging paint. You might need to apply a few times and allow to soak, but with a little elbow grease you'll get there ;) .
Re: removal
Posted: Feb 26th, '14, 14:28
by AndyG
Yeah, Hair dryer/Heat gun carefully.
Old credit card to remove thick glue (warmed up)
Panel wipe to remove residue of glue
Re: removal
Posted: Feb 28th, '14, 14:59
by driverbrook
Thanks to all for tips on removal of the mudguard embellishers, they are now off will no damage, used all the tips you recommended and they worked a treat, thanks to all.
Re: removal
Posted: Mar 6th, '14, 21:29
by GhostlySM
Petrol works wonders to get off residue too! Just make sure you use a clean rag
