What should I be aware of/not do, any tips etc?
I haven't got any carb cleaning spray because it's been said a few times on the net that it's sh*te.. other methods are blasting each jet with an airline (which I could do in the workshop but ideally want to keep the work at home) or sticking the jets in boiling water/strong solvents..
Which is the best way to go about this? The carbs are also being balanced in the week so the problem should hopefully be solved.
Would it be worth sticking a new air filter and fuel filter on at the same time?....
Many Thanks,
Tom.
