stuck
stuck
any advice on getting screws and bolts out that cause this.. :lol: :?
delvey91
First Name: JACK
Re: stuck
Post by delvey91 »
could always try my way?
2011 Yamaha WR450F
2004 CCM 404DS
julian
Re: stuck
Post by julian »
use a diamond tip, digs in and wont 'cam out' so easily but if you still cant do it you could use an impact screwdriver :D
[img]http://www.dynamight.pwp.blueyonder.co.uk/sig/juliansig.jpg[/img]
Re: stuck
Try using an impact driver or driver bits on a socket spanner. Get the tightest fitting bit you can to avoid rounding off the screw head. Or buy better quality screwdrivers :wink: !
Re: stuck
I have an impact driver if you want to use it
Re: stuck
I always give the heads a sharp tap with a flat punch before attempting anything, impact driver is your friend, make sure the bit is fiting well before attempting anything
Re: stuck
drill and an 'easy out'
Re: stuck
billinom8s wrote:drill and an 'easy out'
we use em at the hangar the snap on ones are near £20 a pop! I can't ruin the screw though as I need to keep it. :|
Sixth Gear
Re: stuck
Post by Sixth Gear »
You could try some thermal stress, either heat it with Oxy-Acetylene or a plumbers blow torch, or freeze it with some quick release freeze spray. http://cgi.ebay.co.uk/FREEZE-SPRAY-QUIC ... 2c54fdd3b2
Andy 075544 32993, Honda [b]CB500S[/b]. (don't laugh it's faster than my old CG125 :-)) Dropped once, got crash bungs now. I don't suffer from 'insanity', I enjoy every minute of it!
[img]http://i976.photobucket.com/albums/ae246/Sixth_Gear/HeatSeeker4.jpg[/img]
Re: stuck
Sixth Gear wrote:You could try some thermal stress, either heat it with Oxy-Acetylene or a plumbers blow torch, or freeze it with some quick release freeze spray. http://cgi.ebay.co.uk/FREEZE-SPRAY-QUIC ... 2c54fdd3b2
i'l try freezer spray we've got shit loads of it in the vending machines but it doesnt work as well on steel. steel although depending on the composition has a lower coefficiant of expansion/contration than ally which is what we usually use it on. The only thing heat could be used for is to break any corrosion between the threads inside. Other than that it will just make the jammed bolt even tighter :| Today I broke another new (STRONGER) screwdriver on the f*cker and and ive also resulted to using screw grab and yep the screw bit fit perfectly but still not the slightest sign of movement! :evil:
sighhh all good fun :)
Re: stuck
Got the fxcker out! :lol: :roll: Victory is mine.
