Installing a Steering Damper
Re: Installing a Steering Damper
I know this thread is a little old but the link does not work so does anyone else have a how to for a steering damper? As I got one with the bike but it's loose in a bag with no fitting instructions lol
2006 Kawi zx6r 636 in Greeeeeeeen
Bring it over
Ah now the text message makes sense
After having no steering damper on the Triumph 675 I borrowed for Portimao I can tell you that things get quite scary at 140 mph as the front end is desperate to shake its head all over the place had to literally pull back on the bars the whole way down the straights just to hold it straight. you don't realise what an important job they do until you don't have one.
Just need to go to the gym.menzies3032 wrote: ↑Nov 16th, '24, 22:18 After having no steering damper on the Triumph 675 I borrowed for Portimao I can tell you that things get quite scary at 140 mph as the front end is desperate to shake its head all over the place had to literally pull back on the bars the whole way down the straights just to hold it straight. you don't realise what an important job they do until you don't have one.
Some people find it easier to push the bars to lock out rather than pulling back on them, can be worth a try.
