micron exhaust
mac-1
micron exhaust
Post by mac-1 »
hi people im not the most switched on person with things like this but i have tryed to remove the baffles from my micron exhaust on the bandit but when doing so i found in side the end of the baffle is spreed out like a Y shape this meens i cant pull it through and jams, the baffles im told are removable so can i do it with out messing it all up or and i just stupid and doing something wrong...lol. you dont have to answer that bit :D
AlexG
Post by AlexG »
Is the person who told you they are removeable a reliable source of information?
I don't have first hand experience (or 2nd, or 3rd for that matter) of Micron cans, but it might be easier to answer the question if you could take a photo or two... 8)
mac-1
Post by mac-1 »
bridge fitted it and said the baffle can be removed but will give the bike flat spots and that i just needed to remove the screw and that is as far as i have got as the baffle will not pull all the way out
In which direction are you trying to take it out? have you tried the other way?
mac-1
Post by mac-1 »
OTHER WAY? iv tryed taking it out from the end of the can. the screw holds in in place..yeah? then just pull in out? :?
andy198712
Post by andy198712 »
hi means take the can off then slide it out the bottom?
good luck, best to rejet the bike too
Indeed I did :D
