I've heard that I might have to re-jet the carbs for my new exhaust. Does anyone know if this is the case? Also, how will I know if they need re-jetting? Does it make a funny noise, down on horsepower maybe? I think the 400GreyBike forum are getting tired of my remedial, cape-tugging questions
Re-jetting Carbs for New Exhausts
Little Loris
Thought I'd better start a new thread for this as it's a slightly different topic!
- Mike Daytona600
It helps. Get a k&n air filter as well if you can. Check out Dynojet and see what they do for your bike. The only way to see if it's been done before is to check the number on the jets in the carbs.
Parker's
Valeting
Service
Tel: 07751883056
Valeting
Service
Tel: 07751883056
Little Loris
Are Dynojet a local company? I don't suppose you have contacts for them or a web link?Mike Daytona600 wrote:It helps. Get a k&n air filter as well if you can. Check out Dynojet and see what they do for your bike. The only way to see if it's been done before is to check the number on the jets in the carbs.
- Mike Daytona600
Here's the link but doesn't look ike they do one for yours. Might be worth giving them a ring.
http://www.dynojet.co.uk/jetkits/prices ... n-road.php
Parker's
Valeting
Service
Tel: 07751883056
Valeting
Service
Tel: 07751883056
andy198712
..and if it runs too lean, you'll [censored] your engine up bit time, you can make a bike overheat with a too lean mixture, this can cause problems like holing pistons, seizes etcandy198712 wrote:the reason to rejet is, it'll be a bit lean in areas and will have flat spots in power, ie you'll accellerate and wen it hits say 8k rpm it'll feel down on power till say 10krpm stuff like that
and it might back fire more ect
If i were you i'd do some rearch, i found DJ kits to be over priced crap, half the stuff they had in there stage 1 kits for my bike the carbs already had in them on a standard UK SV. The kits were designed for the US SVs running crappy K&N filters and after market exhausts.
Just putting in new jets won't be good enough either, it needs to be set up properly on a dyno to check the mixture is running right, to lean and as said it'll cause problems and too rich will cause performance and economy problems
corse saying all this i'm contradicting myself as i've not had mine dyno'd while i've been re-jetting mine, i've gone on feel
To true, BMC are far betterJon B wrote:A K&N filter will do nothing. They are just overpriced pieces of crap.
Little Loris
