Little Loris wrote:VTR - You might be right on the fuelling thing. How do the carbs get out of balance? I haven't really touched them since it was running fine. And how do I go about balancing them again??
Carb balancing is quite easy, if a bit fiddly.
You'll need a set of vacuum gauges & small pair of hands
The procedure is usually in the Haynes manual, but basically you'll need to lift/remove the tank. On each carb there'll be a small port that will either be blanked off by a screw or a rubber blank, tip;- the vacuum hose coming from the tank will be attached to one of the carbs, this is the port & all the other carbs will have a blank in the same place. Remove the blanks from each carb & attach the hose from each gauge. Start the engine & allow it to reach operating temp....now the fun starts!!!
Basically what you are doing is adjusting the throttle positions of each individual carb so they all have the same opening/delivering the same amount of fuel air mixture. So you'll have one carb (usually number 1 cyl) that will be the master which can't be adjusted & will be the one that you will use to adjust the rest to. The rest of the carbs (2, 3 & 4) will have a screw to allow adjustment of the throttle position, this is usually on the underside of the carbs which is why it can be fiddly....especially on V motors....& can result in rather warm hands
Once you've got them all reading the same, snap throttle open & allow the revs to settle, check the gauges. If the readings are still identical, you're done, if not re-adjust the carbs & give the throttle another snap. Keep doing this until the readings are all the same. When you make adjustments the idle speed will probably change, so you'll have to keep adjust that too.
