Clutchless shifts
Clutchless shifts
hi there,
i am curious what is the purpose of clutchless shifts and is it safe to do so? only up shifts though.
sorry if this is a repost.
andy198712
up fine and standard practice by me for years, but only when really giving it some, ie on the way home from work, or on RWYB days etc
downshifts a big no no
the advantage is in my opinion that theres less delay in change time, and acceleration will be harder and faster IMO as thers not the opportunity for clutch slip etc as its fed back in after changing gears
a mate will come bail you out of jail. But a true friend will be sat next to you in the cell saying "jeez that was fun!"
If you want me Im on the other end of 07710 424947
liek watters says. for every ady use , u may aswell use the clutch. after all if u werent ment to use it they wouldnt put one on. no need to do cluthless shifting really if u decent u can apply a tiny bi of cluth and get the same effect. only time i ever use cluthless shifting if wen im ragging if and its in high revs and this is the only time i would sujjest doing it. it can cause problems if u dont do it right and i personaly dont go down gears wihtout clutch although my mates do.watters wrote:without a slipper downshfits are never to be done imo, when giving it some ive always done cutchless upshifts,seems to be a lot smoother and quicker
get nice high revs bring a big of pressure on the the gear lever, take away the slack. then quickly ease off the throttle by just a fraction, and pop it up a gear.
thats how i do it anyways. if done properly u wont see the front end dip, it should stay at the same height, and u get a nice smooth quick acceleration.
thats just they way i do it though. peeps have their own way,
but in short. dont bother if u dont need to.
enjoy
Banditmax
andy198712
down changing can be down clutchless but there is a fairly high chance of it not goin well if you mess it up and making a nice crunching noise
i down change clutchless at low ish revs, you apply downward pressure and as you roll off the throttle you slot it in, can be very smooth, can lock the rear slightly, best done offroad as the wheel will skid more and put less pressure on the gears..........
how about noooooooooooooooooo. lmfao. could u imagine how long i would have to wait for the spell checker to go through all the mistakes???tafflade wrote:
baskie - cna you please use a speellchackerrr, your poast es rilly ard to reed
i'll see what i can do
