'Clutchless' Changes
Dave
Post by Dave »
Anyone else do this :?:
I'm told that it won't do the engine any harm, but it can save the clutch alot.
I don't do it changing down, or with pillion, but I Can get a well quick change without the clutch :wink:
What's your opinion on this :?: :!:
Jak
Post by Jak »
I do it quite often ... makes changes much quicker and as I've only got little hands it makes my life easier too 8)
my mind not only wanders ... sometimes it leaves completely
I do sometimes but 99% of the time I forget and use the clutch
clunk
Post by clunk »
I usually do it on up changes, especially if i'm getting a move on.
Never on down changes as my SV tends to lock the back wheel at medium/high revs even when using the clutch, unless you blip it when you pull the clutch in.
It doesn't do any harm on up changes , but I 've always read never to do it on down changes.
Griff
Post by Griff »
Always on the upshift, NEVER on the down
Cars are for comfort, bikes are for SPEED Gk76[img]http://img36.photobucket.com/albums/v109/Griff916/Griff916_sig.jpg[/img]
age
Post by age »
I never use clutch on up shift but do on the down shift when you can bang it down two or more gears and slip the clutch back in 8)
PS3 name lesnage
greg
First Name: greg
Post by greg »
I use up the box, never down. Particularly good when carrying pillion, kick up at peak torque, keeps it much smoother than using clutch. Of course Dave as you ride a Suzuki you would be best snicking it up, as a Triumph rider I find brutality works best.
greg
First Name: greg
Post by greg »
greg wrote:I
What I really meant was I don't use up the box, down I do.
CRAIG-GSXR750
Post by CRAIG-GSXR750 »
personally i use the clutch as i go by the assumption of, If its gonna F- UP its allot cheaper to replace a clutch than it is to replace a gearbox
Previous Rides : TS 50, KWAK KR1S 250, GSXR 600 SRAD
Latest and greatest: GSXR 750 K4
::A vacation is a countdown T-Minus your life and counting::
[img]http://img.photobucket.com/albums/0803/Escort_Racer/Kirstys/Sigs/sigsigcopy.jpg[/img]
Jewell
First Name: Ed
Post by Jewell »
use it all the time....
I love Lamp.
Claud 14.7 to 1
Post by Claud 14.7 to 1 »
Oh Dave in reaction to your first post.
I'd rather replace a clutch than a gearbox.
I use clutch-less if i'm going hard on th power through the gears, etc. If im riding sencibly I use clutch all of the time, both up and down. No point in doing clutch less inmy, you dont need to be fast and you will be putting the box through unnecessary strain IMO.
Hi
[img]http://img.photobucket.com/albums/v123/ruizclaudio/rasp2.gif[/img]
My bike: http://img.photobucket.com/albums/v123/ruizclaudio/Soutwestsigbikepic.jpg
ZXR400Lee
Re: 'Clutchless' Changes
Post by ZXR400Lee »
Kawsaki gearboxs are horrible and clunky...I tend to use the clutch all the time, unless I want to get off the start quick against other bikes, friends on there 400's...all other bikes bigger just leave me on acceleration anyway..:P
I always use the clutch...
as i have never tried it with out it....
But i will have a go later on the up shifts:)
andrew
Post by andrew »
In the end this comes down to personal taste but from what i've read in the past doing clutchless UP gearchanges should cause no short or long term damage to the bike as long as its done right. Clutchless gear changes should be done on a neutral throttle - i.e. when the engine is under any great load (either from decelerating or accelerating).
Down gear changes should be done using the clutch as i believe otherwise u can damage the gearbox - but more importantly without uing the clutch u are at greater risk of locking up the back wheel and as age says u won't be able to change down as quickly if u don't use the clutch.
Personally i do clutchless up changes 99% of the time and always use the clutch for down changes (unless i feel really lazy)
andrew
GeorgiasGrandad
Post by GeorgiasGrandad »
Done clutchless changes for 45 years, bikes, trucks, buses and cars. Never done any harm. 8)
