Wurth dry chain lube
age
Re: Wurth dry chain lube
Post by age »
deej wrote:can find out for you
Who's the rep Deej ?
PS3 name lesnage
will be big chris for some of it and the loser that replaced kev for the other area
think george white swindon have some but im not 100%sure
philh
Post by philh »
Scotty wrote: Philh, I've used PJ1 for years and it's not bad at all - the secret, as with any lube I guess, is to spray it on when you've just finished a ride, then your chain is warm and it'll penetrate everywhere quickly and dry properly. The worst thing you can do is spray just before you ride, whatever you put on will fling off as it hasn't dried properly...
That sounds like a good tip. Cheers for the info! I've just had a new chain and sprocks fitted for the summer so I need get my act in order when it comes to chain maintenance. I want to make this one last! I'll pick up some of this Wurth dry stuff too though next time I'm in SP. 8)
andyrh
Post by andyrh »
Gsxrage wrote:any good motorcycle dealer 8)
That counts Riders then :shock:
andyrh
Post by andyrh »
That counts Riders out then :shock:
they wouldnt stock it as it would upset shell too much
SlowR1der
Post by SlowR1der »
i have just had new chain and sprockets fitted as well, can the same stuff be used on x ring as well as o ring chains? (that is any chain lube not just Wurth) also Deej/Age dealers for Hampshire that stock as well please.
bambam
First Name: Jon
Post by bambam »
i just got some of the wurth stuff to try from total triumph in taunton.
so if i find it's no good i'll be round age's to spank his b#m for recommending it :wink: :wink: :wink:
age
Post by age »
GSXRsi wrote:i have just had new chain and sprockets fitted as well, can the same stuff be used on x ring as well as o ring chains? (that is any chain lube not just Wurth) also Deej/Age dealers for Hampshire that stock as well please.
Yes it's fine on Xring chains 8)
Any good motorcycle dealership will stock it 8)
bambam wrote:i just got some of the wurth stuff to try from total triumph in taunton.
Oooerrr I am only about 3 miles away from Total Triumph :lol: :lol:
PS3 name lesnage
have they actually got it on display now bambam ?
should be suitable for all chains but remember to give the can a really good shake first,anoither good tip is to keep it warm
bambam
First Name: Jon
Post by bambam »
no mate not on display.
came out of the 'workshop' ohh err
gonna give the chain a damn good clean first cos it is minging and then try the dry lube.
gotta finish off the old stuff first seeing as it was free
