Acumen DG8
Acumen DG8
Has anyone fitted one of these, I'm thinking of getting one for my R6 but £80 is a lot to part with if it's no good?
webster
Re: Acumen DG8
do you really need to know what gear you're in? as long as the revs are ok for the speed you're doing it doesn't really matter what gear you're in
Re: Acumen DG8
just fitted one to the r1.
bit of a pain taking the nosecone off and some of the fairing to route the wiring but works fine.
i take it for £80 it's the plug and play version with the wiring loom??
Re: Acumen DG8
Well, when you flick it up in first or third either way is not fun!webster wrote:do you really need to know what gear you're in? as long as the revs are ok for the speed you're doing it doesn't really matter what gear you're in
Re: Acumen DG8
really, u did?bambam wrote:just fitted one to the r1.
i have fitted 3 so far, great pieces of kit. worth every penny.
Re: Acumen DG8
Worth it imo. Its one of those things you dont think you'll need until you have one then you use it a fair bit. I have gone into 7th gear since I fitted mine
If you are handy with a soldering iron, then save a few quid and buy the DIY kit. It isnt that hard.
Re: Acumen DG8
I bought the Datatool one, I always told people that I never really used it.
However I never actually realised how much I did use it until I rode a bike without one.
Bloody brilliant item.
If you go the Acumen one, stay away from from the DGV as it doesn't work.
- deej
- First Name: Dave
Re: Acumen DG8
Dave wrote:I bought the Datatool one, I always told people that I never really used it.
[Censored] brilliant item.
SNAP
Although i'd go for the acumen over the datatool
Re: Acumen DG8
i just bought a dg8 is it easy to teach it the gears after it's fitted any tip's??
Re: Acumen DG8
Yeah fairly easy, you need a paddock stand then just follow the instructions. I set mine up about 2 years ago when I got it and its never faltered.
