Which Chain Lube??
Re: Which Chain Lube??
gunk is good for removing grease n stuff.
when wheel is clean give it a good coating of mr sheen, the silicon barier should help prevent fling sticking
- deej
- First Name: Dave
brake cleaner will remove it from your rims,along with a bit of elbow grease
- Mike Daytona600
WD40 is ace at removing grease, gives the rims a bit of a shine and some protection to.badgerKDD wrote:on the subject of fling, who would recommend what for cleaning it of my rims? Been using a mix of degreaser/ old washing up sponge ( with the green bit on) and also white spirit. Then loads of soapy water.
Any quicker, less labour intensive methods?
A while back I did a post on valeting bikes, I used to do it for a living. Here's the link
viewtopic.php?f=16&t=83110
Parker's
Valeting
Service
Tel: 07751883056
Valeting
Service
Tel: 07751883056
You need to use the wurth chain cleaner from time to time !VTR wrote:Used to use Castrol Chain Wax, but have recently started using Wurth. It does go on clear, but after a while will still attract dirt like any lube/oil.
That must be because your putting it on thick.tutton wrote:Use wurth dry too.
Shame the cans never seem to last very long.
It's all I use and yes I do work for Wurth
PS3 name lesnage
PS3 name lesnage
- thelastsuperpower
Great for chain fling and grease, rubbish for removing brake dust on white wheelsMike Daytona600 wrote: WD40 is ace at removing grease, gives the rims a bit of a shine and some protection to.
Bikeless again :/
dougal_999
I used some Muc-off bike Degreaser the other day, surprised how well it worked. Just spray it on, leave it for a couple of minutes, agitate with a brush if required then rinse off. It's water soluble too, so doesn't matter if it gets on brakes or tyres.
I clean and lube my chain often, currently use Kal Gard as it was on special. No complaints yet.
I use paraffin.....but we've been thru that discussion beforeGsxrage wrote:You need to use the wurth chain cleaner from time to time !VTR wrote:Used to use Castrol Chain Wax, but have recently started using Wurth. It does go on clear, but after a while will still attract dirt like any lube/oil.
I use virgin blood to lube my chain. If it's good enough for for a hymen, it's good enough for me...
- Mike Daytona600
Alloy wheel cleaner. The stuff I've used has never removed paint but make sure you read the lable girls and boys.thelastsuperpower wrote:Great for chain fling and grease, rubbish for removing brake dust on white wheelsMike Daytona600 wrote: WD40 is ace at removing grease, gives the rims a bit of a shine and some protection to.
Parker's
Valeting
Service
Tel: 07751883056
Valeting
Service
Tel: 07751883056
VTR wrote: .........I use paraffin.....
Where do you buy paraffin nowadays
i managed to get a gallon last year from an oldie hardware shop but thats closed down now
new mob no. 07714415952
- badgerKDD
- First Name: Badger
HMM my favourite Hymen is 'All Things Bright and Beautiful', never took you for a religous man FunkyFunky wrote:I use virgin blood to lube my chain. If it's good enough for for a hymen, it's good enough for me...
Badger's from near Redruth - no such thing as a virgin there.badgerKDD wrote:HMM my favourite Hymen is 'All Things Bright and Beautiful', never took you for a religous man FunkyFunky wrote:I use virgin blood to lube my chain. If it's good enough for for a hymen, it's good enough for me...
Chain Lube - PJ1 Blue (not the black) nice & thing to apply, little but often at the end of a ride. For those with no main-stand, just lean the bike over onto the side-stand & prop up with a length of 2x1 under the swinging arm near the wheel spindle - easy.
Oh, and chainlube - whats that
I have a scottoiler ......... other than topping it up every few hundred miles, can't remember the last time I had to grub around on hand & knee dealing with sh*tty chains
