Just been to get a quote from Johnsons to get my leathers dry cleaned, 90 quid for jacket and trousers!!
Is this normal??? what do you guys do with yours?
Dry cleaning your leathers..
Re: Dry cleaning your leathers..
pm lwr gerry, she knows all about that stuff
If it's just the outside that needs sprucing up, then I've always found that a good scrub with baby wipes followed by a proper leather wipe/feed works great!
If the inside is stinky then I guess you'll need something more...
dougal_999
All I've ever used is Nikwax Leather Cleaner and then the Restorer which waterproofs too. In all honesty I've never done the insides so I don't know! Hmmm that makes me sound scummy doesn't it...
Mine go in the washing machine on a low low low heat wash. Says its ok on the labels so i guess its ok.
Although that only gets done once a year if that - usually its just cleaning the outside, in which case i just use a damp cloth, and then proper leather wipes, and then a leather feeder.
- LWR GERRY
- First Name: Gerry
http://www.leathermagic.com/Pages/careforleather.htm
I think you should read up on leather care before you think about putting them in a washing machine!
Hope this helps.
Also, this was put up ages ago but full of useful suggestions!
http://southwestbikers.com/viewtopic.ph ... a&start=15
http://southwestbikers.com/viewtopic.php?f=36&t=80165
Hope this helps.
[img]http://i6.tinypic.com/11v09r4.png[/img]
I do the outside with NikWax leather feed.
The inside gets a quick burst of sanitiser spray, same stuff you get for doing insde helmets & boots. Stick them on a hanger & leave them outside for a couple of hours to air out
[b][i]You don't stop playing because you get old, you get old because you stop playing[/i][/b]
[i][b]Far better to be a bit late in this world than early in the next[/b][/i]
