nitrogen
Re: nitrogen
Personally, I use helium to reduce the unsprung weight,
Re: nitrogen
i use vulcanised rubber for my tyres.
as the gravity is lower on that planet the rubber is lighter here so in theory makes me go faster - isn't working yet tho
Re: nitrogen
Try routing your dylithiam crystals through a zoned parsec field it worked for me.
Re: nitrogen
mattblack wrote:Try routing your dylithiam crystals through a zoned parsec field it worked for me.
do you not find the warp field ripples counteract the benefit of the dampening stabilisers causing weekeness in the tyre wall ?
Re: nitrogen
no. your just making it up now.
Re: nitrogen
nope, my dad told me
Re: nitrogen
I've managed to fit warp flux capacitors to mine. Work a treat upto 88 miles an hour...
Re: nitrogen
Funky wrote:I've managed to fit warp flux capacitors to mine. Work a treat upto 88 miles an hour...
and then you crash
