if so what you think of them?
cheers.
I didn't mean not blipping throttle when down shifting. I meant don't blip throttle as you turn ignition off/hit kill switch. I know alot of people do it but on the 918cc models it seems to fill the intakes with fuel & when you start next time, they backfire through the carbs. I knew of 4 blades which did this & they all stopped it if you just hit the kill switch when the bike was ticking over.GIXXER KID wrote:ideal, thats gunna be well wierd cus i always blip its as i drop through the gears.
cheers
deej wrote:That's not good at all then,didn't think I'd seen you hooning around it much
As for the wheel allow about a 100 quid for repainting, there's a place in wadebridge but I can't remember their name at the moment
Where?billinom8s wrote: just get it powder coated, u can do a pair for about £60 and it'll last longer than a spray job
