Gsxr 600 k8 help
Stikley
First Name: Nik
Re: Gsxr 600 k8 help
Post by Stikley »
Marty636 wrote:
Croddman wrote:I am that freind with the GSXR lol :-)
A mode is 100% power from the engine
B mode is 75% power from the engine, however as Nik says this will jump to A mode if you are screaming the tits off the bike, but you realy have to be screaming the tits off it to jump as the power delivery is still fantastic
C mode is 50% power from the engine FULL STOP it will not jump to B or A no matter how much you push the bike, it will still do over a TONE! but it just takes a couple seconds more to get there.
C mode is really good on long jurneys great on saving fuel and you can still have fun however A is the best :mrgreen:
If you need help setting up the REV light on the dash I am more than happy to help, its good when you worked in a dealership lol.
Is the rev light that big white light that comes on when u turn the key??? suzukis r so difo to the kawaks
Yes the white light that comes on the clock unit is the rev light, can be programed on or to flash at the revs you want it to. Yes Colin is the friend with one, but needs me to set it up lol
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
Marty636
Post by Marty636 »
sorry 2 b a pain in the ass but ive noticed a lil tiny red light that also pops up wen u turn the bike on,just by the speedo onthe right had side by the temp gauge. :-bd
Marty636 wrote:sorry 2 b a pain in the ass but ive noticed a lil tiny red light that also pops up wen u turn the bike on,just by the speedo onthe right had side by the temp gauge. :-bd
Oil light? It'll come on for a few seconds when you start it up and go out when the bike has built up system pressure..
Stikley
First Name: Nik
Post by Stikley »
Same as above! Nothing to worry about unless it says FI, meaning Fuel Injection problem and not F1 racing mode. Main problem on GSXR is exhaust cables seizing. Lube the cables at the same time as you do your chain and it will be fine. Cables are on the Right Hand side of the bike as you sit on it, down on the exhaust, going onto the valve in the downpipes. WD40 will do, it will burn off when warm and exhausts get hot so that's why you do it with the chain every 300-600 miles
1994 Kawasaki ZX9R
2002 Aprilia RSVR
Marty636
Post by Marty636 »
Stikley wrote:Same as above! Nothing to worry about unless it says FI, meaning Fuel Injection problem and not F1 racing mode. Main problem on GSXR is exhaust cables seizing. Lube the cables at the same time as you do your chain and it will be fine. Cables are on the Right Hand side of the bike as you sit on it, down on the exhaust, going onto the valve in the downpipes. WD40 will do, it will burn off when warm and exhausts get hot so that's why you do it with the chain every 300-600 miles
cheers my friend
Marty636
Post by Marty636 »
ok i give up,could u please tell me how to change the rev light indicator,ive tried everything i no,i even manage to change the mph to kph lol
Stikley
First Name: Nik
Post by Stikley »
Turn off ignition, Press both and hold both buttons, turn ignition on while holding buttons down, select light on (indicated by lightning bolt), select brightness (1-5), select rev limit. Hope this helps. I think it is in the owners manual too.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
And here's a pic of this machine of mystery..
..some mud monkey behind
Marty636
Post by Marty636 »
Stikley wrote:Turn off ignition, Press both and hold both buttons, turn ignition on while holding buttons down, select light on (indicated by lightning bolt), select brightness (1-5), select rev limit. Hope this helps. I think it is in the owners manual too.
well i wod of never of guessed that lmao once again thank you.
Stikley
First Name: Nik
Post by Stikley »
It's a bit of a fun one, I always programed the new bikes to have the rev light come on for the running in period before they left, then on the first service I asked the customer when they would like them to come on and showed them how to do it at the time.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
Marty636
Post by Marty636 »
Ive got another pain in the ass question for u,ive asked the gixerjunkies forum but they couldnt really give me an answer, ive noticed when i hit roughtly over 4/5revs when riding i can hear like a very light buzzzzzzzzzzzzin noise like a bee in the front section of the bike,im pretty sure its nothing in the engine but as a pannels is not done up 100%(but ive checked them all) or a cable lighty vribrating agasint something,but this noise is not there when im just reving up,is this common?
Stikley
First Name: Nik
Post by Stikley »
Ive got another pain in the ass question for u,ive asked the gixerjunkies forum but they couldnt really give me an answer, ive noticed when i hit roughtly over 4/5revs when riding i can hear like a very light buzzzzzzzzzzzzin noise like a bee in the front section of the bike,im pretty sure its nothing in the engine but as a pannels is not done up 100%(but ive checked them all) or a cable lighty vribrating agasint something,but this noise is not there when im just reving up,is this common?[/quote]
Croddman has the same problem, it's coming from the screen, he replaced his for a doublebubble from skidmarx and it got worse, I have a few friends that have got GSXR600K8 but they haven't said of anything either. Check the screen screws. Is it a standard screen? Judging by the picture it looks like a pattern one. PM Croddman and see if his still does it.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
Marty636
Post by Marty636 »
Stikley wrote:Ive got another pain in the ass question for u,ive asked the gixerjunkies forum but they couldnt really give me an answer, ive noticed when i hit roughtly over 4/5revs when riding i can hear like a very light buzzzzzzzzzzzzin noise like a bee in the front section of the bike,im pretty sure its nothing in the engine but as a pannels is not done up 100%(but ive checked them all) or a cable lighty vribrating agasint something,but this noise is not there when im just reving up,is this common?
Croddman has the same problem, it's coming from the screen, he replaced his for a doublebubble from skidmarx and it got worse, I have a few friends that have got GSXR600K8 but they haven't said of anything either. Check the screen screws. Is it a standard screen? Judging by the picture it looks like a pattern one. PM Croddman and see if his still does it.[/quote]
Ya its a DB screen,but not sure what make koz it came with the bike,can i just say ur A GOD!!!!! lol ^:)^
Stikley
First Name: Nik
Post by Stikley »
Just have a wealth of knowledge still when it comes to Suzukis. Thanks anyway, I hope you get it sorted but mainly enjoy riding it!
1994 Kawasaki ZX9R
2002 Aprilia RSVR
"ahh it sounds like a bee!"
