Hello people,
On my mirror base which is made of aluminium the paint that is covering it has started to flake and look really nasty anyone have any advise or know anyone that could spray it to solve my problem ?
Cole.
Spraying Aluminium
- Croddman
- First Name: Colin
Spraying Aluminium
[img]http://i.imgur.com/LN3yf.jpg[/img]
Riding With Style
Mehhhhhh SpongeBob............
Riding With Style
- Stikley
- First Name: Nik
Re: Spraying Aluminium
Get a can of spray paint and do it yourself, I would.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
2002 Aprilia RSVR
As above - DIY
Rub it down well and give it a spray of satin black. I've found PJ1 engine paint to be very good. With this weather, warm the item to be sprayed gently with a hairdryer (speak to an R1 owner for one of those) and warm the rattle can in a jug of hot water - the paint sprays much better when warmed, and settles better on the item being sprayed with a reduced risk of running. Plenty of light coats rather than one or two thick ones
- Stikley
- First Name: Nik
What he said. I'm sure even you can do that Colin
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Aprilia RSVR
I believe hairdryers are the weapon of choice for gixxer riders.
R1 owners use GHD's, don't you know anything Moose ?
Smootherite do a satin black which is a good match - I've done the side stand on the Hayabusa and it looks original.
Be careful using it on aluminium, build up with very very light coats and do each coat in the time specified on the tin. It can be wierd stuff, I have had it react with itself when left too long between coats as it seems to go into a curing process.
- Stikley
- First Name: Nik
Yeah, currently riding one and also need a hairdryer when spiking my 8 inch mohawk!billinom8s wrote:I believe hairdryers are the weapon of choice for gixxer riders.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Aprilia RSVR
