I have a cbr400 nc23 i am working on as a project bike with a friend. It was running well after just putting a new battery in. Then after being left for a day it wont fire at all. It turns over fine but no spark.
The guy who had the bike previously said this was happening a lot with this bike and it worked perfectly every time they replaced the plugs, so the question for you guys is what is killing the plugs? I have had them out and they look perfect, just not sparking anymore.
Bike wont fire.
Re: Bike wont fire.
check kill switch, over a period of time water gets in and carrodes the contacts.
just a thought...........skippy
Re: Bike wont fire.
Try being friendly and introducing yourself to the
forum, people tend to be more responsive to manners.
23s do have a range of starting issues.
Re: Bike wont fire.
I apologise, I completely forgot about introducing myself here. I guess I was distracted by how difficult it is to type long messages on my phone.billinom8s wrote:Try being friendly and introducing yourself to the
Re: Bike wont fire.
no probs,
check things like
fuel supply - is it on a hill ? those bikes dont have a fuel pump so are gravity fed
micro switch on clutch lever - engine cut out
stand micro switch - engine cut out
kill switch - open up the casing and check the contacts on the switch, clean them up.
wd40 and wire wool could be your saviour.
what have you tried ?
check things like
Re: Bike wont fire.
The fuel supply seems to be fine. It does have a fuel pump, which pissed petrol all over my leg, so that is definitely pumping.
As far as I can tell all the cut out switches are fine too.
The weird thing is the fault seems to be temporarily fixed with a new set of spark plugs, but after a couple uses the plugs stop working.
- Stikley
- First Name: Nik
Re: Bike wont fire.
Plug caps? If a fresh set of plugs makes it fire maybe it's the connection on the caps themselves, maybe change the set, NGK plug caps for a set of 4 should be £10ish
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
2002 Aprilia RSVR
