Done an oil and filter change on the trumpet. Since I got the bike the throttle has been really snatchy when rolling on. I heard about this program that allows you to dial into your ECU. I bought a VAG cable from fleabay and thought I would give it a go. This software is free and allows the diagnostics of Triumph, Benelli, Aprilia and KTM Ecu's, basically Keihin and Sagem manufactured ECU's. I downloaded a new map and reset the TPS (throttle position sensor). Fortunately I know a bit about pc's and the like and this is not for the faint hearted.
No more snatchy throttle
http://www.tuneecu.com/
This is free. You can change maps and stuff so if you put a race pipe on your pride and joy then upload the map for it, reset the TPS and away you go no more dealer fees to change maps
