r6 tappet noise
r6 tappet noise
pretty new to biking i have a 99 r6 with not really noisey tappets but you can hear them as that normal? Also an irregular idle please help
greg
- First Name: greg
Re: r6 tappet noise
Noisy tappets and irregular idle would go hand in hand, been properly serviced? If it doesn't have full history and no recent service I would be inclined to get it done.
- Grumpy Git
Re: r6 tappet noise
sounds like the carbs need balancing, something not always done as part of a service (cheapskate garadges) unballanced cards means the cylinders are fighting one another and can cause both symptoms. Could also be cause by water in the carbs from condensation if the bike is left standing for more than a few days this weather.
[size=200][font=Times New Roman][color=darkblue]Dark and Moody [/size][/font][/color]
[url]http://www.darkandmoody.co.uk[/url]
[size=134][color=darkblue][font=Times New Roman]For Unusual and Gothic Clothing
[b]I dare you [you] to be different![/color] [/font] [/size][/b]
- Claud 14.7 to 1
Re: r6 tappet noise
How many miles has it done, and when were the clearences last checked?
If you have to do the valves, get those done, and then balance the carbs and It'll be running sweet.
I have same kinda problems, but I'm going to leave it till the spring/summer because in the hotter months the problem gets much worse. Now it's running quite nicely. And I cant be bothered to spend ££ on it.
at the mo.
Nice new(er) R6 I'd get it done asap. My bike is old and not worth nearly as much.
Re: r6 tappet noise
If the clearences on the valves are a little loose itll rattle some but it wont hurt it.
