Stand height
Simon101112
First Name: Simon
Stand height
Post by Simon101112 »
Evening all,
I have changed the dog bones on my bandit 600N to give a higher seat height, ( I'm 6'6), can you get longer side stands? Or is there a straight forward mod?
Si
Re: Stand height
Does it need to be longer? When I raised the height of my B4 the bike stood a little higher on the stand but wasn't in any danger of falling over. If you definitely want it longer find a local engineering workshop and I'm sure they would weld an extension piece into or onto your current stand.
Ruffian
Re: Stand height
Post by Ruffian »
We have just had to do this with a mates ducati monster,
He has raised it about 75mm and was very lent over when on the side stand,
All we did was weld a stud extension (very long nut) onto the side stand to make the stand longer,
(With doing it this way if was still to short a bolt could be wound in to make even longer)
Re: Stand height
When I raised a previous bike, I just cut down a 1cm thick bit of alu, drilled two holes and countersunk it to the bottom of the stand. Nothing a drill and angle grinder couldnt sort in an hour.
carlos1982
First Name: carl
Location: dawlish: rides VTR1000 firestorm, yamaha r1 4xv, gsxr 600 k4 trackbike
Re: Stand height
Post by carlos1982 »
when my storm fell over i came across some adjustable sidestands??? didn't get one in the end as i found a longer one off a different bike which was a direct replacement. but they are available!
