Posts: 3592 Joined: Mar 15th, '14, 14:06
Post
by MellowYellow » Jan 19th, '16, 23:24
Some wretch tried to nick my bike this evening. The immobiliser prevented them.
However, they have ripped the wiring out of the ignition and damaged the lock with (probably) a screwdriver.
Too cold and dark to do anything so I left it and walked home.
Will go back tomorrow to assess the damage and make plans as to where to have it taken.
Posts: 20540 Joined: Sep 10th, '05, 22:31
Post
by billinom8s » Jan 20th, '16, 03:08
Hopefully it's still there.
Have you REALLY pissed someone off or something?
don't forget we are on
X and
Instagram believe it or not !!!
KTM 690 supermoto smc R ,
Stinker
Posts: 125 Joined: Dec 23rd, '15, 06:36
First Name: Adrian
Post
by Stinker » Jan 20th, '16, 06:41
Jeez....that's shitty. Really sorry to hear this.....hope things are not too bad.
Triumph Rocket III - Enough Torque To Turn The World
Posts: 7148 Joined: Dec 14th, '05, 22:59
Post
by TLS-Moose » Jan 20th, '16, 11:39
Have you considered moving? I know parts of Bristol have a "reputation", but I have never known anyone have the kind of grief you have
Post
by MellowYellow » Jan 20th, '16, 12:54
Had a traumatic time getting it onto a slip-slidey recovery truck.
Tiz not the area, best guess is that it was someone from the hairdressers-trying-to-kick-a-ball cup replay just across the river.
Light at the proverbial end is that...(a) I have another ignition switch, and...(b) I won't have to drill out the hardened bolts as I can swap the complete top yoke...I think !!
Post
by MellowYellow » Jan 20th, '16, 17:48
Goody, swapping the yoke will work.
Had to resort to the torque wrench to get the required leverage to undo the 30 mm top nut.
Tomorrow is another day...and so to bed dear reader.
Posts: 4997 Joined: Apr 21st, '08, 19:59
Post
by badgerKDD » Jan 20th, '16, 19:55
MellowYellow wrote: Goody, swapping the yoke will work.
Had to resort to thetorque wrench to get the required leverage to undo the 30 mm top nut.
NOOOOOOOOOOOOOOOOOO!! You naughty naughty boy
, go and buy a long bar, its cheaper than buying a new torque wrench.....
Posts: 1775 Joined: Jul 29th, '13, 18:06
Post
by Ruffian » Jan 20th, '16, 21:14
Motor parts direct atm have 1/2" 2foot long breaker bar with lifetime Warrenty even on the knuckle for only £15 ish.
Definitely worth the investment.
Glad it was an easy ish fix for you though
Post
by MellowYellow » Jan 20th, '16, 21:58
I've had both advices re torque wrench. Some say it's OK...screw it up to max and don't continue if it clicks. others say it's not to be used to undo nuts.
Needs must as the devil drives, and I have no other transport. D/y on breaker bars from the net was uncertain and I need the bike back on the road asap.
It's only 65 megatons, so I went for it. Will get a bar soon (ta for the heads up Ruffy) . Might need to have the tank off tomorrow to access the main multi-plug.
So cold, need a
break every 10 mins.
Post
by MellowYellow » Jan 21st, '16, 09:34
Update. Both yokes off.
Drat...need to take tank off and it's bl**dy cold. First coffee and calorie break ongoing.
Post
by MellowYellow » Jan 21st, '16, 14:35
Turned the key...nothing.
Nothing more I could do. Distraught, cold, hungry. Sun well over the yardarm so sat down with a glass of something dark from the West Indies.
Immediate brain massage...could it be...YES, 30a fuse blown. Vroom !! First kick.
Post
by badgerKDD » Jan 23rd, '16, 07:09
Result! Glad your back on the road, now to find the scum who tried to knick your bike and really put that torque wrench to good use ;) ......
