Robbo87 wrote:green_hodgeheg wrote:It definitely starts with the clutch held in if using the electric start and kicks over without it held in. ........................................ this is definitely how mine works.
Well it would do and this is normal. Pulling in the clutch lever when using the kick start disengages the engine from the clutch mechanism, therefore not allowing the engine to 'turn over'. Pulling in the clutch lever when starting on the button will not do this because the electric starter motor acts directly on the engine, it doesn't act on the clutch mechanism.
It's a gearbox thing
Correct about the starter motor but not always the case about the kickstart:
depends if the kickstart operates onto the outer or inner clutch basket. On bikes where it works on the outer basket, you can start the bike in gear with the clutch lifted (like most off road bikes).
Some bikes work on the 'gearbox' side of the clutch & through the inner basket, can't be kicked over in gear (feels locked as operating the gearbox output - rear wheel) and with the clutch lifted (in neutral) the kickstart simply turns the clutch inner basket and not much else - you were doing either of these rather than trying in neutral with the clutch lever out.
Some Suzuki two strokes worked the oil pump in the same way - could seize if the clutch was lifted for long durations.
Surprising what you learn once when trying to sort a gearbox problem.
Scotty's right about the cutout switch though, instead the Kawasakis of this age had the most awkward sidestand retraction mechanism built into the clutch lever.
